New person, Hi! On vacation and would love to get this boat running, this is my first time ever using a boat, though I have been working on this one for the past week or two and test drove it Saturday at home.
I've looked through no-start threads but haven't found this situation.
1978 Johnson 115 Engine will turn over and if it doesn't start it gradually turns slower and slower.
Add jumper cables/another battery and it doesn't help so it's not the battery.
Eventually it won't turn over at all, turn the key and you get nothing.
If you wait awhile (15-45 minutes) - it'll start (PUN!) all over again....turns over...gets slower and slower, then nothing.
If you get it all just right and get it to turn over on the first or second try (rare) it runs fine.
I copied down the master starting thread here and want to look at the ignition switch and work back from there.
*** One problem I have is that I have no idea how to remove the ignition switch - 1978 Glastron and i've got all the screws removed that are obvious but the two halves holding the switch in place won't come apart?
