I have a 94 Johnson 115. Was a trailer queen I have been getting back into working order. Already been switched to premix before my ownership.
It would run fine at WOT but would stumble and die while at low speed in no wake zones. Last time out it would also die at WOT unless I would constantly have someone pumping the primer ball. Between these outings I had to replace the trim motor.
I have checked the water separator, fuel line fittings, and obviously fuel in the tank.
Pulled the fuel pump out and pulled that apart, Appears to be no cracks in the diaphragms. There is a 4 wire plug going to the oil side of the pump that is now blocked off. This was disconnected. Is it still needed while running premix? If not should I rebuild the pump anyway?
Thanks for any help
Gary
Thanks for any help
Gary
