Spoonriger
- May 2, 2005
- 35
i have a 1974 50hp evinrude that has been in storage for 3 years,seems to run fine on test muffs,but not sure of the impeller, there does not seems to be a pee hole,but motor does not appear to be running hot.it has a hydro-mechanical lower unit,according to the manual (clymers) i need to remove a bolt under the lower carb to disengage the shift level,i can not seem to find this bolt.thanks for any help
