Took the ski out for an hour and ran fine with no problems then just died and would not start. One of the carbs is shooting to much fuel down inside. Any suggestions would be appreciated
you need a carb rebuild including a new needle and seat. I'd also reccomend replacing all of the fuel lines as the original gray ones weren't designed to handle the ethanol that is now in fuel and breaks down, causing the fuel system to gum up and burn through top ends.
