HELP!!! Noise, smoke and now Motorguide 82# won't shut off
nirud2204
I was on the water today, in the rain. I was using the TM and I heard a"short" noise like a soft pop from the front of the boat. The motor shut off and wouldn't work. I got it to come back on using the bypass switch. When it came on a puff of smoke came from the top of the trolling motor. Now it won't STOP running....HELP!!!
alldodge
Howdy
Sounds like you burned up the relay or contactor. Going to need to take some things apart and see what is burnt
jbcurt00
Welcome to iboats nirud
Please notice the helpful tip at the top of a forum page and try to avoid posting in topics that are inactive (been 90+days w no new posts). Its been nearly a year since Role started the other topic you posted to, and 6months since he logged on to iboats. You arent likely to get a reply. That topic is now closed.
You'll get better help, specific to your problem w your TM here in your own topic.
alldodge
Where should I start?
We are unable to see what your looking at, with that I would suggest removing anything you can to get into the unit. My guess is it's toast and cannot be repaired, but need to get it apart to see what is burnt
