MNBlizzard
- May 15, 2009
- 7
OK, so yesterday morning I looked out to see my motor which is a 2004 250 HPDI in the full up position which is not where I left it. So, this had happened one other time about 3 months ago. Then the problem just went away. This time it will not do anything. When I activate the up or down switch, the relay just clicks. Nothing to the trim motor. I have check voltages and everything looks like it checks out. I believe the trim motor is shot. Any other thoughts?
Also, how in the hell do I remove the trim motor. It has 3 allen head bolts, one which is conveniently buried. I tried with no luck to drop it out of the frame. I removed the 4 bolts from each side, drained as much fluid as I could and I still could not get it to come out the motor frame. It appears that I cannot get it to go up high enough, due either to the frame rubbing or the center piston fighting me.
