I have another thread here (http://forums.iboats.com/prop-questions-topics/tohatsu-50hp-prop-advice-needed-605893-2.html) but thought I make a new one because I need an answer ASAP as I am only with my boat for 3 more days and also because my original thread is an old one and I doubt new people will look at it because its a couple of pages long!
Anyway...
I finally got round to buying a Solas 11 x 15 propeller to replace the OEM 11.1 x 13 Tohatsu one which at WOT would hit the rev limiter at 6000 rpm!
I fitted it today and unfortunately I have to say I am very gutted! =( I am getting bad cavitation, I think that's what it's called where the water comes splashing up behind the transom. It never used to do that with the old prop! Also my WOT rpm with just me in the boat has now gone from 6000 rpm on the rev limiter to 5000 rpm!!!! and my max speed is down about 2 mph too!
Why on earth have I lost 1000 rpm?! I was expect a reduction of 300 - 400 rpm by going up 2" in pitch (with an increase in top speed!) and also I was not expecting bad cavitation if that's what the splashing I am experiencing is called. I have just done about 2 hours research but I am still none the wiser on whether this is cavitation or not! Do I need to raise my motor up one hole to stop this splashing problem? TBH I don't want to do this and don't think I will be able to, if I had known this would have happened I would have simply stuck with the OEM prop! Hopefully I can get a refund if this isn't going to be a simple fix! Though thinking about it surely I shouldn't have to change my engine height as it was absolutely fine before, no splash at all, all I have done is changed the 13" pitch prop for a 15" pitch one!!!
Lastly I also noticed the exhaust note is slightly different now with the new prop. Thought I'd say in case that's a clue to the problem as it's a through hub exhaust prop!
I appreciate your help, thanks everyone!
Anyway...
