Hey Guys,
As I was putting the finishing touches on my new motor, one of the starter bolts was not torquing up properly (yes I was using a torque wrench). When I removed the starter, this is what I found!
I bought this engine as a short block and heads and was finishing the assembly with plans to reinstall in the boat tomorrow...
Is there a reasonable repair at this point, or should I (gulp) disassemble the engine and return the short block for a replacement? On close inspection it looks like the mount was repaired with a Timesert that was flush with the rail (there appeared to be Loctite red between the Timesert and the block), rather than sunk below the rail like its matching hole.
Any suggestions?
Thanks,
Mike
Any suggestions?
Thanks,
Mike
