Re: HELP!!!Need to Winterize 1992 Merc. 115...How?
Paulfred, if you look at the link backlash said, you will be ok, and fishthebay has good advice also. The part I have to add is that the merc 115 is a 2+2 engine, so you need to remove the plugs on the sides of the two bottom carbs. They are brass. This is because a 2+2 only idles on top two cylinders, so you can't run the bottom two out of fuel, unless you are hard in the throttle. Draining is safer though. If you don't, that oil/fuel mix will be sludge by next season.<br /><br />If you wanna know anything else about the 2+2, let me know, I've learned most of my knowledge the hard way so I am willing to give it out.
