fishonboat
- Jun 23, 2003
- 52
I have a 1991 Tiderider Jetski that was manufactured by SOS marine. Ok here's the problem. The motor runs great at idle up to 3/4 throttle. At full throtle it almost seems like it's hitting the Rev limiter. I do know that is has one from looking in the service manual that I just picked up. Orgianly I tought that it wasn't getting enough gas to the carb at full throttle. So here's what I have done. I rebuilt the carb and the fuel pump that is attached (carb is a Mukuni BN38/34 round body style), replaced the fuel lines and fuel filter, Replaced the vacume line from the fuel pump on the carb to the crank case, freash gas mixed 40:1, new spark plugs and compression checked out at 140 even on both cylinders, I set the high speed needle at 1 turn out as it calls for in the owners manual and made adjustments in 1/8 increments to richin the mixture all the way out to 2.5 turns and it ran worse. Ran worse meaning that it bogged down at 1/2 throttle. Like I said it runs and starts great but at full throttle it misses like it's running out of fuel or there is air in the fuel lines. I did replace the fuel line with transparnet fuel lines so I can see there is no air in the lines. I have pulled the plugs after every adjustment to check there color and the factory settings on the carb needles seem to burn the best. The plugs are brownish black and dry. After flipping through the service manual last night I saw that there is a rev limiter. Now I'm starting to wonder if these things can go bad. I did have one person tell me that they think that the coils are breaking down. I tend to disagree. If the coils are breaking down I don't think it would run at all or it would run horrible. Any thoughts as to why this thing sounds like its hitting the rev limiter or running out of fuel? It's sounds and feels like a consistent miss. Thanks for your help in advance
