blugrasmaniac
- Apr 29, 2013
- 37
So, I was in the process of torquing down the retainer bolt for the upper mount on my 175hp Evinrude V6, and although the manual says torque to 100ft-lbs, after quite a bit of cranking, although the bolt was getting tighter, something just didn't seem right. I stopped around 60ft-lbs to take a closer look.
When I did, I found that the bolt has bottomed out and pushed through the block wall into the water passage. See the pictures below.
I'm not really sure why the bolt is too long. I took the block to a shop to have the cylinders shaped up, and they took the mount off for me and put it in a box. It is possible, though, unlikely, that I got the wrong bolt back.
Anyway, bottom line - how can I save the block?
