I recently purchased a new bass boat that has a 2002 Merc 150 XR6. I've had a out a few times now and I've noticed a issue. The motor runs strong, but when I idle at low speed for more than 2 or 3 minutes (such as through a now wake zone) the over heat alarm starts to sound. (one long constant buzz). This doesn't ever occur when just idling at the dock or when cruising at normal speed. It will stop if I shut the engine off for a minute or 2 and I've noticed it will also shut off if I start running at speed. When idling through these no wake zones when it goes off the water pressure is usually around 8psi according to my gauges and at cruising speed closer to 12-13psi. Any idea what the issue could be? I'm wondering if there's some kind of thermostat on the engine?
