I am hoping someone can help me with a trick or way to get the tapered plastic insert in the hose on the transom side. I have the special tool and have been able to get the insert in on the bell housing side, but I can't get the insert at the transom side to start threading in. There is VERY LITTLE room to work and I have spent about 6 hours today messing with this. I have the hose in place, and I am spinning the tool and insert but it won't grab.
I even tried spraying starting fluid (read it on another site) in the end of the hose to try and grip it. I could try to push it in farther before I start turning, but I am afraid the hose will slide back. I really appreciate any advice anyone can give. I am about to pull my hair out!
There is very little clearance between the back of the engine and the water inlet housing. If it helps, it is a 2004 Four Winns.
