Help! MerCruiser 4.3 v6 Not sure what model or year of engine and outdrive!
passnbyu
Hi, I'm new to the boating world but I'm looking forward to starting my first boat rebuild. I bought a 1977 Wellcraft Airslot 21 with a preformance trailer. Well I traded a 95 Grand Am Gt with a blown head gasket for it. Payed $400 for it. The motor is locked up tight. It has a MerCruiser Alpha one 4.3 liter V6 (ser. number C617865) and a Alphia one outdrive (Ser. 08989191?). The outdrive is hard to see.
The boat is in good shape. I know this is not the original motor or outdrive. I need to find a web site that I can tell what year and model this motor is. I also need to find a service manual for it. It seams MerCruiser has a lot of different manuals for the 4.3's.
I can't wait to get started on this!! I'm going to try to pull the motor this weekend. I have a rebuilt 1989 4.3 liter V6 out of a Chevy astro van. Its just been bored, new piston, rods re-sized, new cam bearings,crank turned, new rod and main bearings. It even has new brass freeze plugs. I'm going to use the cam out of the marine engine when I put it together.
If any one would have any info on the engine and outdrive, it would be a big help! Also should I use a marine gasket set. Like copper head gaskets? It has a heat exchange.
Thanks to all how read and respond to this!! I like this forum!!
Passnbyu
Re: Help! MerCruiser 4.3 v6 Not sure what model or year of engine and outdrive!
if you have the serial numbers you can call mercruiser and find out what year and model
Don S
With the serial numbers you posted, the engine is a 1989 4.3L engine, with an Alpha I transom shield, assuming the 08 in your serial number is actually a 0B that B can look a lot like an 8 when stamped.
Here are links to download the proper OEM service manuals for your engine and outdrive.
Engine http://www.4shared.com/document/1FdjddET/Service_Manual_07.html
Outdrive http://www.4shared.com/document/zz_5pj9o/Service_Manual_06.html
passnbyu
AWESOME! :) This is great! I'm downloading them right now! I can't wait to start. That 89 out of the astro van should be the same block. I still would like to know if I need a marine gaskets set or can I uses the auto set I already have. I know I'll still need gaskets for the heat exchange unit and a couple of other things..
Thanks for all the info! You guys are GREAT!!
Passnbyu
