In this pic
how does the spring that pulls A back (i have been told it is under the flywheel)...over power the spring that is marked with the green 1? I assume it doesn't and the actual control cable is what should pull A back to an idle position. Is this correct...please help me understand the mechanics using the numbers and letters that are marked.
The problem is that the lever at C is not coming back far enough hence the high idle. Or does the arm NOT come back and I am suppose to adjust the idle elsewhere?
