Help me identify these mystery wires. Mercruiser 350
synergy141
Hi, Just buttoning up my Mercruiser 350 install. I didn't remove the motor myself as the previous owner had a shop do it so I don't know where everything goes. Just wondering if any of you know where these wires and hose go. Pictures are attached. Thanks.
synergy141
This fuel hose with the red stripe.
muc
"Retired" Association of Marine Technicians...
1st pic --- to engine ground stud on bell housing. 2nd pic ---- purple wire is 12v+ key on power, maybe coil? Black with ring terminal might be an extra wire, it's a ground wire. Black with bullet connector, might be for trim gauge. 3rd pic and 5th pic --- you should have a fuel line between the tank and fuel filter, it looks like you have 2 fuel lines, do you have an extra filter mounted somewhere? 4th pic ----- metal bracket helps hold the gear lube bottle in place and the plastic piece is a cover for the starter slave solenoid.
