slackjawed
- Jul 2, 2009
- 4
Hi folks. First time poster, so thank you in advance for your wisdom. Boat being discussed is a 2001 Maxum 2300SR with 5.7L (2bbl) MerCruiser (GM 350). 270 hours on the engine, rack stored.
Had a small leak which my mechanic was having trouble locating. This has now led to a laundry list of repairs. If you could let me know how many hours (labor only, no parts) each SHOULD take, it would be VERY helpful to me so that I can confirm my mechanic isn't taking me to the cleaners on labor costs. I will try to be brief; this is the order in which the repairs were done:
1) Replace risers/manifolds
2) Install new bellows kit (U-joint, exhaust, shift, gimbal bearing, etc)
3) Replace Water pump
4) Remove engine
5) Replace cracked inner transom plate
6) Reinstall engine
I know this is an inexact science and many factors can affect how long a repair takes. But if I get a ballpark or range (ie 2-3 hours) it would be great. When I get few responsese, I will post the amount of labor HE is saying each repair will take (at $150/hr!!!)
Thank you!
Gordon
4) Remove engine
6) Reinstall engine
Thank you!
Gordon
