help...just splashed resto project and have dive issues!
solar7647
Ok, I just splashed my project for the first time today. The engine is a 3.7L Merc that was was rebuilt with a new long block and is running awesome. Its super smooth in neutral but when the boat is put into drive it develops a loud knock like metal on metal coming from the rear of the engine. I cant figure it out, its only when under load. The knock is also followed by a bogg in power as rpms increase. When the motor is not in drive its smooth all through rpm range.
Any ideas
solar7647
Re: help...just splashed resto project and have dive issues!
oh and yes the engine was aligned with the proper tool and slid in super smooth when it was installed.
cr2k
How was your gimbal bearing? U-joints?
solar7647
Well just to close this thread up, I found the issue. The drive gear on the disributor has a flat spot on it that was causeing it to stop rotating and causeing the #4 piston to miss fire. It would run fine at idle with a small miss fire I thought was do to a dirty plug, but when it would be put under load it really miss. so i have a new gear on the way. Lesson learnedm should have inspected it better when it was put in. I know the new cam gear didnt cause the damage because there was no sign of it on it at all. so the wait continues.
