Help! Joihnson 9.9 hp 1986 wiring..do ihave electric start or not?
appleo
Just bought a 9.9 kicker johnson 1986 that was remote shifted and throttled from the helm
The Prior owner started it for me with pull rope. ran fine shiftrd fine
I get it home and looked closer under the hood and find what appears to be a starter...and a 4 foot battery cable
Help!
1. Also pelase advise what the black electric button is on the remote braket.
2. How would a 9.9 electric starter be actuated?
Any advice appreciated
PS i hooked the battery cable to a jumper pack and nothing99a.jpg99c.jpg99d.jpg99d.jpg99a.jpg99f.jpg99g.jpg
hardwater fisherman
Re: Help! Joihnson 9.9 hp 1986 wiring..do ihave electric start or not?
i cant see the first letters but the E is for electric start and the L is long shaft. the CB IS the year 1986. the white color should be a johnson. it looks like the stop button was moved from the lower cowl onto that bracket.
This model is electric start from the factory.---------These motors did not use a starter solenoid.---They used a heavy duty push button switch.--That switch was mounted on the starboard side of the steering bracket.-----May have been moved for convenience of operation.--Trace the battery cables to see where they go.
BigB9000
Well Im jealous.
A little odd that the remote steering kit has the starter button on it...but whatever.
Not odd at all.---That is labelled as the stop button-----The throttle cable goes thru where stop button used to be.--Need more pictures to see if start button is still in the original place.
appleo
Thanks where a wiring diagrams can be located?
