Help Joe Reeves
MooseHootie
Could you tell me if my 1973 115hp envinrude lower unit will fit on my 1978 85hp envinrude.
ledgefinder
Ensign
Re: Help Joe Reeves
Don't think so. In general, the 1973-77 V4 lower units are the same. The exception, I think, is that the 1977 140 used the newer lower unit. <br /><br />Is the trailing edge of the skeg straight up& down (like your 1973s), or does it slope back?
Joe Reeves
Re: Help Joe Reeves
Moose.... The 1973 unit will not interchange with the 1978 unit. There are many differences and the shift rod setup is completely different.
MooseHootie
Re: Help Joe Reeves
Both look exactly the same, same bolt pattern same shape.
walleyehed
Re: Help Joe Reeves
As Joe said, the shift rod is different if your unit is truely a 78'. shift rod changed in 78', my 77' is the same as a 73'. :)
