help installing cdi stator on 85 merc 50hp
les morgan
Have pulled flywheel to replace stator on my 1985 merc 50hp and found the
wiring is color coded differently on the new stator. The old "red" stator has
4 wires--2 yellow and one green with white stripe and one white with green
stripe. On the old stator the two green wires go into a black rectangular
box under the main wiring connector and come out with one blue wire and one blue with white stripe wire which go to the switch box.
On the new stator it has 6 wires---2 yellow, 1 blue, 1 red, 1 red with white stripe, and one blue with white stripe. The two red and blue wires with
the white stripe are marked for 3 cyl motors.
How do I hook up the different colors? Do I do away with the black rectangular box..?
Thanks in advance
Les
ricksrster
Re: help installing cdi stator on 85 merc 50hp
I got this to work, I hope.
les morgan
Thanks for the pics and schematics. But after having a big "duhhh" moment
I went and looked at my switch box and it had the right color coding stamped
into the box itself. I guess the original had been replaced before with one
that had different color wires.
