Help idenitfy serial number on johnson/evinrude engine 15 hp
AlTn
first photo in that group, the number on that disc is the serial no.
Thestigman
I looked up ways of decoding the serial number but they are all way different in structure than the one on the dish any way of dexoding it in year and model
Or is that impossible with this tulype of serial
AlTn
if you want a model no. using your serial no....try brp customer service....seems to be iffy.... can you make out any no.s from the white rectangular area on your stern bracket in the 4th. pic?
Thestigman
The rectangular area was the first thing i tried to check i tried removing the paint on the area since i thought it may be paint over but the only thing under the white paint is steel so that's nothing.
i'll try contacting BRP customer service as you suggested
anyway thanks for your help sir
flyingscott
silver disc is the serial# It's a 93 or newer the recoil is on top and Evinrude goes more by model # than anything
