Help ID year
glagace
I am trying to identify what year is that new old outboard just acquired. I suspect the cowl does not match the motor. Cowl says Evinrude 20 and the plate from Evinrude Canada says model: 209CR02R and Serial: C7062530. Please help me clarify. :confused:
glagace
Re: Help ID year
Thank you Bear, can you explain how you came to this conclusion? I do not doubt the answer cause it confirms other infos I had and that the cowl was replaced with a more recent one, just want to learn.
glagace
Re: Help ID year
Thank you so much Bear, it seems I've been had but at least I learned something from you and a good lesson, check first. Thank you again.
