billengelman
- Aug 20, 2001
- 6
While changing the gearcase oil on my 1979 35hp Evinrude, I accidently removed the pivot pin instead of the correct screw that is unfortunately located just to the left of the pivot pin. I remember a mechanic telling me once to never remove the pin because the guts of the gearcase will fall apart inside and the whole thing would have to be taken apart and reassembled. I was able to jiggle the pin back in the hole and screw it back in. Did I do any damage? Will I have to have it reassembled? Do I wait until I get the engine running again next season, shift it into gear and see if it works, or could I do even more damage by doing that?
