HELP I NEED A WATER PUMP FOR 1989 force outboard
montie1197
Hello All I need some help I bought a 1989 force us marine 50 hp motor serial number is 1061 model number is 507x9a and I need a water pump and cant find one have the money and need it asap any idea where I can find one???? :mad:
notsunkyet
Re: HELP I NEED A WATER PUMP FOR 1989 force outboard
they have them here on iboats will be under mercury name for yours... look for impeller or impeller kits
montie1197
The one is made by us marine and I was told a mecury part would not help??? Any idea if that is is true or not?
roscoe
Mercury bought out US Marine and took over parts distribution.
You just need to make sure the parts are for the correct year/model, regardless of the supplier.
These parts can be purchased at any Mercury dealer, or online, or on ebay. There are no aftermarket manufacturers of these parts - for your motor.
The water pump kit is part FK1073. $140
Just the impeller is part number F433065-2 $16
http://www.dougrussell.com/partscat...150,140,100,120,110,30,170,190,160,180,20,130
montie1197
Thank you so much that helps a ton I am going to buy two so in three years I have and extra one LOL! Thanks again./
