HELP - I get a strong shaking ~3,000RPM
I've got a '97 Cobalt 23LS with the VP 7.4GL DP - only ~170 hours. It cranks fine, idles fine and then I get a pretty strong engine shake around ~3,000RPM, but absolutely no shake until then. I've recently had the plugs, carb and distributor cap replaced.
I suspect two possibilities - fuel issue (failing pump, restriction, water in gas) or EEM issue (bad module, bad sensor(s), corrosion on a sensor, etc.) that's kicking the engine into SLOW mode. Seems like SLOW mode engaging would gradually reduce the engine speed w/o the shaking? I realize I'm screwed if the EEM itself is bad as this is out of production.
Any ideas?
Should also point out that compression has been checked on all cylinders and tested good. The shaking happens when I rev the engine in neutral or when the drive is engaged, so I'm leaning towards an engine issue rather than drive.
Ayuh,..... Welcome Aboard,....... I'd suspect the previous work done,.....Verify, before movin' to other causes,....
