HELP I can't get my motor realigned
Lirksdad
Recently replaced the motor in my 98 Chaparral 1930ss. Purchased long block from Michigan Motorz swapped everything over besides new coupler just because. Put the motor back in and the coupler was out of wack so it wouldn't line up probably because I was cheap and purchased an after market one. So pulled the motor and I put the OEM one back on and it looks dead on but I cant get it to line up the splines with the alignment tool. Everything was installed correctly, Spring and fiber washers in the rear everything tightened I've adjusted the front mounts 100 times up and down by as little as a quarter turn and can't get the tool to go all the way in. Any help would be greatly appreciated.
Scott06
there is a mercruiser procedure for centering the the gimbal bearing by inserting the tool and smacking it L, R, Up, down
How far in does the tool go and what do grease marks look like ? I had to jockey my engine side to side when I did my repower
Might be worth checking the tool dimensions vs dwg in the stickies or have you used this tool successfully before
Lirksdad
I actually have a friend who took the tool to work today to make sure all specs where correct. The tool is going in to the coupler but stops at the splines and this is the first time the tool has been used.
Scott06
That would be a good sanity check . Also seen folks us a 1" pipe or dowel which wont be tight in the coupler but allows you to insert it and look in with a flash light to see which way it needs to move.
Be interested to see if the tool is wrong as that would be easiest solution. Would also double check the mounts are correct so you don't go nuts over something simple. If your original coupler is still ok the alignment must have been decent to begin with...
Did you get a reman or new base engine. I got a partial engine (silver package) from them in fall of 2015 been trouble free since then
kenny nunez
Remove the top nuts on the mounts, with the engine hoist connected to the very front of the engine raise it then back the lower nuts down. Now raise and lower the engine to get the alignment bar into the sweet spot. Slapping the bar around is also a good way to get it in place.
Lirksdad
Remanufactured excellent customer service. Motor is trouble free besides alignment issues. I've been stuck since last Friday lol.
Lirksdad
Been there
04fxdwgi25
Double check that the rear mounting is assembled in the correct order. washer in wrong position throws the whole magilla off.
alldodge
Sounds like you have it centered
Put some grease on the end of the tool. Push in until it stops, pull it out and see if it's high or low
