Re: Help ! Honda 9.9 how do you remove the emulsifier tube ?
Just to let everyone know the result...<br />I managed to get it out in the end, but it was a real struggle. I had to make up a small semi-circular block of wood to place in the venturi to lever up against the emulsifier tube. It finally came free, and now can be put in and out with no problem. I guess it must have been gummed up or something (from new).<br />I'm still trying to find out if I need to replace the main jet (please see my other post on jets). I had read a while back, here and on other forums about upgrading a Honda 9.9 to a 15 by removing the throttle stop and changing the jets (plural) from 48's to 52's. I've now changed the 'jet assembly' inside the emulsifier tube from a 48 to a 52, but the main jet itself has got '102' engraved on it ?
