I have a 1966 40 HP Big Twin, just got it running nice after a full ignition rebuild, carb cleaning fuel line and water pump rebuild. Took it out finally and hit some serious mud at full throttle very early on. Within seconds the engine died and wouldn't start back up even hours later. Took the lower unit off and cleaned out the pump to be safe. Checked spark, it was strong. Plugs were clean. Checked fuel, good as well. Compression was fine before didn't check yet. I'm new to working on motors. What else should I check? Has this happened to anyone before? Bummed after all that work first run was a bonehead move and back to square one. Anything will help thanks.
