scb1712
- Jul 25, 2011
- 105
Hi all - it’s been a while since I posted, but have always gotten good advice so thought I’d try again. I have a Volvo penta SX-M I/o which has a leaking trim cylinder. I’ve tried to ge the piston(s) off but the bottom shaft seems to be seized. I’ve removed the clips and washers from both sides, as well as the keeper nuts on the back. I can’t get the hydraulic lines undone, nor can I budge the bottom shaft. I’ve tried heat, bashing it with a sledge (which only managed to flare the shaft a bit so I had to file it down) but it won’t move at all. I’m open to any ideas
