help finding modle #
sgreen5
i recently got my 1st boat. it is a 1988 bayliner trophy. it has a 305 chevy with omc outdrive. how do i find the modle # so i can order parts for it? i need a voltage reguator and the trim swith to be specific. the local shop said trying to get parts without the nuber is real hard unless its a merc so thanks.
Bridar
Re: help finding modle #
Most sites will require year, make, engine size (ie: 5.0 Liter), 2 bbl or 4 bbl carb, and type of outdrive (ie: Cobra, King Cobra, Stinger, etc). I believe OMC had (4) models utilizing the 5.0 GM powerplant in 1988. The model numbers were 502AMLGDP, 502APRGDP, 504AMLGDP, and 504APRGDP. The first two model #'s had 2 bbl carbs and the 2nd two model #'s had 4 bbl carbs. I'm fairly certain that all 4 models utilized the Cobra outdrive.
HT32BSX115
Howdy, and Welcome aboard.
You can probably just replace the alternator (or pull your alt and have it rebuilt) The regulator is usually inside the alt.
Forget about the trim switch. (on the throttle control right?) You'll probably need to just replace the entire control. Your throttle quadrant is possibly more than 20 years old. OMC went out of business more than 10 years ago.
If there's no model number on the engine it's either worn off or someone replaced the engine and didn't keep the old model numbers intact.
I have a 1987 Four Winns 211 Liberator. It came with an OMC engine, drive and controls. While I could have used the OMC control with the engine and drive I replaced the OMC with, I pulled it and threw it away.
I bought one of these: http://www.teleflexmarine.com/produ...anical-dual-action/ch1700-side-mount-control/
As quirky as the OMC Cobras are, you NEED to have good positive control of the shift system. If the shift quadrant/controls are that old and even a little questionable, I would replace them.
For identification,go to http://epc.brp.com to find model numbers (you can leave the email blank) click the drop down menu and select "Sterndrive" and find your year model. there'll be several model numbers but things like alternators are probably the same for all.
Cheers,
Rick
Bridar
I've attached a breakdown of the model numbers so that you can determine your's. As Rick mentioned, the main parts will likely be all the same. The primary differences between the 4 models will be 2 bbl vs 4 bbl carb, and the prop rotation.
sgreen5
thanks for all the help. bridar the attachment isnt working for me?
as for the trim switch can i just add a 3 way togle next to the controls?
this is what i have. when i got the boat this sumer i had one of the cables changed. it works smooth now so i dont see a reson to change it for a $4 switch??
and for the volt reg. i thought it was the black box with round harnes pulg next to the dizzy? if not what is it?
thanks again
HT32BSX115
Well, it's hard to tell from your picture.
But if I had to guess, would say it's the ESA module.
In 1988, there were 4 models (Bridar indicated above) . ALL of them used the alternator in the pic below.
#24 is the voltage regulator
It's a pretty standard alternator. The alternator that came off my previously installed 1987 460 King Cobra, fits on my 1997 Mercruiser 454.
It's also possible that if it's original, it could be a 1987 model too (boat builders frequently do this) In that case, the OMC part number for the alt might be different but either one would probably work. (87 was a Motorola or equiv alternator)
convert
Oh,
There's no reason you couldn't put a spring loaded center-off double-pole, double throw switch anywhere you wanted to put it and it would still work.
It's just that it's FAR easier to use with the throttle hand since it should be readjusted every time you move the throttle.
That regulator by the way is OMC #985713 http://www.sterndrive.info/voltage_regulators.html you can buy it in a variety of places on the net, ebay etc.....
I would just replace the alternator though assuming it's really "bad".
sgreen5
alright. the volt guage was pined all the way at 16 last time i was out and theboat started dieing unless i was just going 4-5 mph. the volt regulator would be the only thing to couse that right?
either way il take the alt to get tested.
