Help Finding A Part
SoonersFan
I need help finding a replacement engine hood lift actuator for my 2011 Harris 250 Grand Marine SEL. It currently has a Linak LA31-U457-01. It appears this one is discontinued. Mine is currently stuck in the up position. When I press the switch, the fuse button pops out.
alldodge
Howdy
Instead of looking for the original Harris actuator, look for one which meets your requirements. Look on the unit and see what you can find
LA31 is the type
The U457 is Under hatch 457MM extension
Need to know the force and the just search for 12V liner actuators
Or contact Linak and ask them what their new model number is, they are still in business
SoonersFan
Thanks, I didn’t know that the the “457” was the measurement in mm. That makes sense because that’s about 18 inches and the entire length of the actuator when open is about 36 inches. Here’s a picture of the label.
alldodge
Showing 1500 N (Newtons) push thats 337 pounds
Haven't done a lot of research on them, but looking at the 10% duty cycle in 2 minutes of 18 min cycle, isn't much. Might be the reason it didn't last
In any case with that info you can look at other vendors and compare
