Hello, I have my uncle's 1973 evinerude 25hp s#25303 ae0001996.It has no throttle response and feels like it has a miss in engine. It backfire thru exhuast in 55 gal drum. I check compression cly 1 115psi and cly 2 115psi. I checked spark has 1\4in strong and blue in color. I checked the piont settings reset them to.020in. I notice that this little 2 stroke smokes in my opinion way too much than normal(mixing 50:1) and extreme amount of oily muk left in the 55 gal drum.I look up thru exhuast port and it is real milky white in color.Also cleaned carb out, something was blocking the high speed jet. Any suggestions what to do to get this running good again would great. Thanks, Jim
