help electrical problem 1993 5.8 omc
duckstar
boat wouldnt start,cranked but wouldnt fire up fuel pump wasnt priming, checked the voltage on my 1993 5.8 high/LOW PRESSURE was only getting 7 volts ,any help would be appreciated thanks!
Daviet
Re: help electrical problem 1993 5.8 omc
If you bypass the the pressure switch do you get the proper voltage at the pump?
duckstar
not sure what pressure switch your talking about maybe you can clue me in on that !
know_fear
Interesting, I have a similar problem with my 1993 5.8 as well.
Mine would cut out occassionally with little warning. It would restart with a lot of cranking but would then only run rough at best (stumbling) and I would have to feed it lots of throttle so I wasn't able to get it in gear. It would die as soon as I brought the throttle to neutral. So far I've tracked it down to the fuel pump control circuits.
I made up some monitoring LEDs on straight pins that were pushed into the wires to the two fuel pumps. When everything is running properly, these LEDs would be glowing a solid red, but when stumbling they would flash indicating to me that the fuel pumps were being turned on and off rapidly (about four times per second).
The fuel pumps are connected in parallel and engergized by a small relay mounted just to starboard of the foreward (low pressure) pump. I've just mounted an LED across the coil of this relay too see if it is picking up properly but so far the boat has been running just fine.
For reasons unknown, if I shut the battery off and totally power down the system the engine will start normally. This doesn't seem to make a lot of sense unless it is somehow re-setting whatever is causing the fuel pumps to pulse on and off.
When you read seven volts, your volt meter may be interpretting a rapid on/off as a steady seven volts. Do you measure an AC voltage across your fuel pump? If yes, you're probably having the same pulsing as I am and you may be able to start the engine by giving it more throttle.
Does any one have a schematic of what controls the relay that picks up the fuel pumps?
know_fear
So Duckstar have you had a chance to do any testing on your fuel pump issues?
duckstar
tried to start yesterday, fires on a couple of cylinders when i first turn the key then just cranks with no starting only the high pressure pump on the top seems to prime for 2-3 seconds before cranking it, do you know if their both suppose to prime( high and low )before the motor cranks.thanks for getting back to me on this!
know_fear
I don't have a schematic diagram but I followed the wiring on mine and it seems that the two pumps are wired in parallel and powered off the same relay contact. Therefore they should always be running together. Hopefully you just have a connector problem that can be remedied by disconnecting and cleaning.
Does anyone have a schematic showing the fuel pump circuit on a '93 5.8? I'd like to know what energizes the relay that turns on the pumps.
sam60
I have some OMC info that may help. Do you have the engine model number? More info = more help.
know_fear
I hope duckstar knows his engine model # but I may never know what mine is.
I bought mine from a small shop that obtained it as a near "write off". The original owner utterly destroyed the engine by running it with no cooling water running thru it at all. Rather than rebuild the engine, the shop owner/mechanic decided to replace it with new. Any identifying tags went to the scrapper on the old block. Were all of the 1993's multi-port fuel injected and were the models radically different? Tough questions but this is the best place to ask.
duckstar
no fuel was getting to the fuel rails ,no fuel out of the pressure relief valves ,upper high pressure fuel pump primed for 2 seconds but lower one didnt so we bypassed the relay and ran 12 volts direct to the lower pump and just the top one worked so gonna replace the lower one and hope it works!12 volts was ay the fuel pump when we turned the key on then dropped to 8 volts, i will try to get the engine model # THANKS
