So after using my boat multiple times a week since the start of boating season, I was out fishing and noticed an electrical fire under the hood of the engine. Two wires rubbed and burned. One Green, one Black. The green wire is melted right to the black one. They go into a plug that I have pictures of. I pulled the wires out and traced them all the way to the transom mount where they go in and Im not sure where they go from there. The harness is melted all the way to that point, and I couldnt cut open anymore. I don't know what to do from here and would really really like to know what these wires are for. I bumped the ignition key and the motor fired right up with those wires unplugged and melted. ANything at this point may help. Motor is a 1994 Johnson 70HP VRO.
This is the burnt side of the wiring harness. The striped/burnt wire is the green one which burned to the black one. Green one is not part of the plug.
This is the motor side of the plug, unburnt
another picture of the plug. The plugs home is behind the fuel filter
