Help diagnose tilt/trim
EBENZER
guys i looked at tilt /trim today. It was a used unit that came off 85 150.. i tested it by grounding black lead and using green and blue leads to test up and down. Heres what i found. Going up the trim rods come out fine and the tilt works fine. going down the tilt rod goes in first with no movement from trim rods. i here motor churning strong but no trim rod movement..any ideas on this. i hate to pass it up ..good deal..but if it cost alot to fix ill let it go.thanks
dlplost
Re: Help diagnose tilt/trim
Remember Trim moves very slow compared to the Tilt.
If there is any air in the system it may do that, could be that it just needs the air bled out and fluid topped off.
