Help buying a boat 1995 Spectrum 17 PRO Avenger SC
randee
Looking at buying this boat. I just re-read the "For New Members Needing help buying a boat. A Buyer's Checklist" very helpful.
If the seller gets back to me I am hoping to view it this week. I read what I could find on this boat and motor. I read some horror stories about "Spectrum" but apparently in the 1994-1996 range they were still built well, at least from what I have been able to find. Regarding the FORCE 70HP motor, I also have read plenty of bad reviews of the FORCE engine. I hope to keep it running for as long as I can, and if I need to I can repower at a later time.
Of course, it's hard to find a boat in my price range around $3000 that is perfect so I am trying to find something that will get my family on the river safely.
Any other advice anyone would have for me about this specific combo while I am looking it over?
Thanks for any input!
Randy
roscoe
No Title
I had the slightly smaller version, 16'8" Avenger, with the same motor.
The motor is one of the better Force motors.
Easy to work on. Always ran well.
Never fouled plugs.
I geeked out 37 mph with an empty gas tank and no gear.
Normal speed with fishing gear and fuel was about 32.
The 17 Pro is a bit bigger, wider, and definitely heavier, you might get 28 mph.
I was not terribly impressed with the hull, tended to slide through turns at speed, but what do you expect from a smooth hull with no external ribs to grip the water. Mine tended to be stern heavy, but the extra bulk of the 17 Pro should keep it from porpoising. Just don't expect a rocket ship.
Decent boat, not a Starcraft or Alumacraft.
I suggest you take it for a test drive. Check compression.
Check for soft floor and transom.
It looks like there is some weather damage to the carpet, so make sure it is solid underneath.
Mine originally came out of Fox Harbor as well.
harleyman1975
Ensign
My Brother in law has an 18 ft spectrum with a 135 force on it and he loves it! runs strong and is very stable. he paid around $2400 for his from a family member.
