Re: HELP!!! Battery switch shorted out and made negative positive and positive negati
If it still runs after you correct the polarity problems, use your voltmeter to check DC output. Measure at the battery terminals or at the "hot" wire on the starter solenoid. You should get a rising DC voltage as you raise the fast idle lever to, say, a max of 1500 rpm. Don't ever run the motor faster in Neutral on a flusher, it's bad for the innards to run without a load.
If the DC voltage doesn't rise with rpm, or actually drops, the regulator/rectifier assy is fried and needs replaced. You can look up parts here at
www.iboats.com
If you can't find the part here, try
www.boatfix.com
Check this site for parts diagrams (you'll need to know your Serial #):
http://www.mercruiserparts.com/SelectModelType3.asp?class_id=2
Replacement of the reg/rect assy is pretty straightforward, disconnect battery, disconnect wires from reg/rect, unbolt the bad unit and install the new. You may need some heat sink paste (what's used for computer CPU's is great or get some from Radio Shack) for the new unit.
Hopefully the rectifier/reg isn't fried, cross your fingers!
HTH........ed
