HELP! 87' Suzuki 150 getting weird!
greatwhite
Have 87 150 Suzuki Super Six <br />Oil inj removed long ago and ran well.<br />Low oil sensor smoked and melted, wouldn't start.<br />Removed it and will idle on one bank and both will fire and run above aprox 1/2 throttle and above. No spark on that side when cranked<br />Tech said should run fine with oil sensor removed. True? Picked up used one anyway and it still acts the same.<br />*Spark on "good" side weak when checked with tester light(barely lights) but brighter orange when running<br />*Checked all connections<br />*Checked for spark with tester<br />*purchased used stator, not yet installed.<br />*low ohm reading from ic coil<br />*pulsor coils ohm reading ok<br />Hope it isn't CDI cause I can't afford a new one!<br />Used would be ok.<br />Will try other stator today and see if that helps.<br />Could it be the retifier?? Any help outthere??<br />Been down for 3 weeks and the cobia are waiting!<br />Thanks
fridays
Re: HELP! 87' Suzuki 150 getting weird!
I'm sure I have a used one..how can I get in touch with you?
snappernz
have you checked the spark plug leads for breaks ;)
