Just bought a 85hp suzuki and the guy I got it from says it needed to be rebuilt cause the berrings were bad. Had to find out for myself started right up and runs just fine in the yard. But when I took it out to test it and shift into gear runs ok at slow speed but when i give it more throttle it doesn't go and eventually cuts off. If I tilt the motor where the intake is just in the water it will run pretty well seems that when it is under load it won't put out enough power. What could be causing this? Don't know much about motors and just want to get a few opinions before I take it into the shop. Any help would be greatly appreciated. Thanks!!
