Help 72 Johnson 50HP
Scorpionhand
Also, How can I indentify what engine I have? I think that the engine may not be the engine it is registered to be because it doesnt have a breaker point ignition.
G DANE
Re: Help 72 Johnson 50HP
Hi Scorpionhand<br /><br />Its not uncommon to see someone changed the old type ignition to new CDI. On many models they bolt right on, if you can get one from a wrecked motor. On one of the frost plugs it has the model numer stamped. Try to compare to the number on the bracket. If your still in doubt - post both numbers here. It can be hard to repair motors like that ( if thats the case ) as you have to order parts from several vintages !
Scorpionhand
The Power head number is 386399 RPH<br />Mounting Braket ES3646128 (Transom Clamp)
Kiwi
Have a look here for your model number Scorpionhand, you can find the year of manufacture from there. The site is not all in english but its faily easy to find your way. (click on modellguide)<br /><br /> Outboard Serial Numbers <br /><br />Cheers<br />Mike
Joe Reeves
Scorpionhand.... The 1972 50hp Johnson is a engine that incorporates solid state electronic ignition. It does not have ignition points.
