fishinmexico
- Jun 15, 2015
- 1
I have a 2006 Mercury 75 hp four stroke efi. It currently has 82 hours on it. I purchased the boat and took it out once for a 100 mile round trip ride with zero problems. I then took it out a second time and it started cutting out and died on me. I am in Mexico and the closest Mercury dealer is 5 hours away. I pulled the motor off the boat and took it down to the dealer. We found out that the injectors were staying open. He took the injectors out, sent it to the lab and had them cleaned. After he installed the injectors the same thing was happening. He looked around the motor for a ground but he did not find anything. The motors literally looks brand new. He put another used computer in and it solved the problem.
He said that he thought that maybe there was a ground in the harness. When I got back I mounted the motor and checked the harness. The harness also looks like it is brand new. I checked the battery cables and found that the old owner had extended the cables with a nut and bolt and taped it up with electrical tape. The wires were sitting in the bilge in some water. I figured that must of been the problem and mounted the cables up high in a dry cabinet. I hooked everything up and the motor ran fine at idle.
I took the boat out the other day to test it out. I made it a whole 300 meters and the boat did the same thing. When I got back I had a local mechanic come over and we found out that the injectors were staying open again in 3 cylinders. It looks like something fried the computer again??? Any help would be greatly appreciated on what could be doing it. Battery cables look good, motor looks brand new with the cowling off, harness looks new and so does the control. I did notice that when we were cranking hard on the motor that the negative cable did heat up a little bit.
