bluewaterbug123
- Dec 13, 2003
- 7
Help!! 200 Merc W/carbs No Spark
I have a 2001 200hp carbed merc. It won't stare all the time. The only way I get it to start is while I am cranking over the engine, I have to shut off the safty switch ( the one that is attached to the lanyard that attaches to the pilot and in case the pilot is thrown from the controls it will shut the engine down ) and when I flip the switch back on it will sometimes fire up.Usually it takes half dozen tries. the engine will run fine after it starts in all rpm ranges with no problems at all. There is no spark when I try to start it normally, I have to do the switch thing. Any ideas will be appreciated.<br />Thanks<br />Gary.. from Lantana FL
