Re: help - 1999 Honda 90 leaking oil from upper unit
A lot depends on where the oil is coming from. If it is dripping out of the little tube (90 degree tube ) midway up the front of the engine, then oil in in the same area as your flywheel. Not good...
It could be caused by bad oil pan gasket, but could also be the lower crankshaft seal, or a rusted out seal bolt (which is steel) on the underside of the power head. This would be especially true if your shift shaft seal was torn and water got under the powerhead.
Before you go pulling the power head, remove the starter and look inside the starter hole at the flywheel. If there is oil in there, it will be pretty obvious.
Another way to check where the leak is coming from is to clean the oily area with brake clean. Let it dry. Then get a dry powdery antiperspirent at the drug store. Spray it in the area where you think the oil is coming from. Let is dry.
Then use your engine as you normally would and tilt it up as normal to get it to leak. Go back later and you should see the path of the oil.
There is probably something else like that you can buy at an auto parts place...but at least your motor will smell real good with the deodorant.
Mike
