Re: Help: 1996 mariner/mercury 100 stumbling
Like I said I have drained all of the old fuel, from every where including the fuel line, tank, and changed the filters, I can turn redline without full throttle which is 5250. I saw a bit of an over-rev condition and put a 23 prop on it and it did not seem to change anything, the problem is that at no time except for the first second when coming out of the hole can I use full throttle, I can feel it make alot of power in that second, but it very quickly starts to fall off until I back the throttle down to about 3/4 throttle setting, the boat is an 18.5' flat bottom I have not cleaned out the carbs and have been running the boat for the past several months, it had sat since the previous november until I bought it in April.
