Upon further observation, the wearplate has a lot of gasket covering it. When you replace the impeller, replace the wearplate and the two gaskets. Make sure the gasket on top of the wearplate matches the waterpump cover and the one under the wearplate matches the water pump base. Lube the impeller and twist the driveshaft CW while pushing the waterpump cover over the impeller.
