Re: Heat Exchanger Plugs
Yes, But not a threaded plug. I am a plumber so I cleaned up the bad tube with a fitting brush, fluxed it and soldered it closed with 50/50 and light heat. Had to do on both ends. Have not had any problems with it.
If you can't solder, maybe you know a plumber or take it to a radiator shop, I'm sure they can do it.
I don't think the tube's wall is thick enough to tap it, but I could be wrong.
