Boat is in a heated garage and it rarely gets below 32 deg around here ... but I am not wanting to rely on that. It's my first year with this boat and just found that the closed cooling system was removed by the previous owner. I'm using the Owners Manual and Merc Service Manual #18. Steps for Raw and Closed cooling systems are both covered. Do I simply follow the raw cooled instructions?
I've drained and wired the engine block (2 plugs).
I've also disconnected the in-line hose for the power steering cooler.
Now I am wrestling with the hose from the circ pump, and it's NOT gonna budge without additional tools or advice -- Dish Soap?
I've got thumb tabs (one black/one blue) at the bottom of each exhaust manifold, so I"ve got to disconnect those yet.
With the closed cooling system removed, are there any extra steps I need to look out for? I don't think there's any difference in performance? I'm a fresh water guy so I don't think I really 'need' the closed cooling system? I've done 2 days of internet reading over this and learned a lot.
Once I get the circ pump hose off and manifold tabs disconnected, is that it?!! I've got the outdrive removed and gear lube drained.
Another Questionable Story:
About a month after getting the boat, I realized that the engine serial # was scratched out. I've been trying not to freak out about that over the summer... but ... I'm guessing it means a previous owner blew up the engine and had a mechanic rebuild it. Does a reputable mechanic scratch out the serial number as proper procedure? Will it affect my insurance (as in - can the boat be insured?)
Thanks All !!
Thanks All !!
