trail_boss2
Thread starter- Joined
- Sep 3, 2010
- 2
I have a 2002 Sun Dolphin Pro 120, just bought it used a few weeks ago. Did a few things and got it all cleaned up and its a great boat so far and works for exactly what I need it for. When I initially bought it none of the electronics on it worked. (Lights, aerator, trolling motor plug in) I used a voltmeter and determined that my problem was with one of the 2 circuit breakers. (It has 2 circuit breakers, 5a for accessory and 50a for trolling motor) The 5 amp breaker was bad and I could not find one anywhere so I ended up wiring in a 5 am fuse holder and then everything worked great. After the project was done I closed everything back up and the boat sat for a couple of days in the hot garage. When I went out today nothing would work again. I opened the switch panel back up and noticed there was a ton of moisture in there, probably from the humidity. After it was open for a few minutes the lights started working again. Is this something that would be causing them not to work for periods of time and is there something I could do to prevent the moisture from building up in the space? This is my first boat so I am learning as I go.
