HEADS TIGHTENING
CYJMI
Hi<br /><br />for a 1988 VRO evinrude 120hp <br />does anybody know<br />1- the "strength" (or torque in english ??) I have to apply to the bolts<br />2- the order to do that..<br />thx in advance<br />jmm
JB
Re: HEADS TIGHTENING
Moving to Outboard Questions.
dick
20 foot lbs. ,and work from the center out.
93bronco
Ensign
there should be numbers by each hole on the heads. torque in that sequence and in stages. <br />20 to 22 ft. lbs or<br />(24 to 27 Nm)
dick
no # beside the bolt holes on that engine , just work from the center out and you will be fine.
93bronco
Ensign
i have a 1988 120/140 and a 1993 120 spare powerhead and a 120 spare empty block with heads. all three have different part#s for the heads and all three have #s next to each hole designating torque sequence.
